Retired_Member
Apr 28, 2018RBK50 to replace aging Time Capsule
Hi folks,
I'm considering replacing my fifth generation AC Time Capsule with a Orbi RBK50 two unit system in a 2200 sq foot two floor house as my TC struggles to provide distant coverage from the main floor where it's located to my iMac music server in the basement. Average connection speed at the imac server varies from 169 mbps to a max of 219 mbps. While I haven't expereienced stuttering on my clients upstairs when acessing iTunes Home Sharing from the music server downstairs, loading album cover art from that server on upstairs clients can take ages. I'm also going to add more clients around the house which which will increase the load on an aging Time Capsule's network.
My main concern is with the Orbi system's ability to support Wake On Lan and Apple's Bonjour service so my imac music server can be woken when a client requests music from it's library. If the Orbi doesn't support Bonjour this would be a deal breaker for me if I can't access music from that server. Can someone confirm the Oribi system supports Bonjour before I purchase it?
Thanks!
BDA
I would contact NG support in regards to this to make sure.
Retired_Member wrote:
Hi folks,
Thanks!
BDA
Hi folks,
Thanks!
BDA
- Retired_Member
Thanks FURREYe38, I'll send them an email today.
Good Luck.
- Retired_Member
Thanks,
Interestingly, I just found a discussion on the Linksys Velop forum which stated the Orbi does support Bonjour and iTunes home sharing which the Velop doesn't (or it doesn't work.) I discovered the same a few ago after buying a Velop and watching my iMac music server go off line after it went to sleep and refused to be woken when my Macs upstairs tried to open my shared iTunes library. I'd rather confirm it with Support first though before wasting my time and purchasing then returning another product that's simply not right for the job.
BDA
Let us know what you find out.
Hope something will work out for you...
- Retired_Member
Good news ....the Netgear Team replied to an email I sent out yesterday and stated the Orbi system shouldn't have a problem supporting Apple's Bonjour service waking my iTunes server from sleep when a client wants to access music in the house.
I'll report back results when I get an Orbi system in place after replacing my iMac server which is seven years old now and more likely to lose its hard drive vs my Time Capsule.
Thanks again for the advice Furry.
