sh2sg
Mar 19, 2018Apprentice
RBK50: Unknown Device in "Attached Devices"
Firmware 2.0.1.4. Orbi Router in AP mode. In Web Admin Portal, some of my devices like iPhone 6s Plus, iPhone 7 Plus, when they first time connected to Orbi Router, the correct device names (tak...
Apr 04, 2018Guru - Experienced User
Did you do a factory reset after applying the Beta FW to both Satellite and Router then setup from scratch?
You might post this here in this thread so the beta team will be more aware:
- sh2sgApr 04, 2018Apprentice
Is 2.1.3.4 still beta? I thought Netgeat already started pushing it to all RBK50?
I didn't do factory reset, is it necesseary?
- FURRYe38Apr 04, 2018Guru - Experienced User
Appartently they have released v2.1.3.4 to auto update for some.
Yes, please do a factory reset then set up from scratch...
