Eric90i
Aug 17, 2021Star
RBK50 V2.7.3.22 internet dropping
I’ve been experiencing random internet drop out where the orbi’s do not have an internet connection, but the WiFi shows as still connected. The ring lights don’t appear to respond the the error either...
Eric90i
Aug 25, 2021Star
It is the Pace 5268AC. Have not seen the pink ring light when I have seen this happen.
I did the 1 minute power off of the modem and orbi’s after reading your response. Have not noticed a drop so far, but it was not a very frequent issue, so I guess I will see how it goes for now.
Aug 25, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Eric90iAug 25, 2021StarYep, all of this has been done already. I’m doing this by way of dmz. This setup with these devices has been running this way for years now.
- FURRYe38Aug 25, 2021Guru - Experienced User
Wifi is fully disabled on the ISP modem?
Does the top ring light up on the RBR when this happens? Color seen here?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
- Eric90iAug 25, 2021StarYes fully disabled.
I have not seen a color shown from the times I have noticed the dropout.
The orbis are on the same floor approximately 36 feet away from each other.
WiFi neighbors are nearby. When I run a scan with acrylic WiFi home I pick up 3-4 typically
