Architekt
Sep 30, 2019Apprentice
RBK50 viewing devices on network question (a bit more advanced than topic sounds)
My network is set up like this: internet access provider ethernet line enters house and connects to my Linksys router (it's in the garage). All 4 hardwired ethernet ports in my house connect to said ...
- Sep 30, 2019
You are correct. The Linksys router has assigned IP addresses to things connected to the four ethernet ports. Because the Orbi is also set up as a router, it is assigning IP addresses to anything behind the Orbi in another IP space. Devices connected to the Linksys have no way to know that the Orbi IP space exists. The solution is to put the Orbi into Access Point (AP) mode. That way, the LInksys will assign IP addresses to every device, and they can all communicate with each other.
CrimpOn
Sep 30, 2019Guru - Experienced User
- CrimpOnSep 30, 2019Guru - Experienced User
Because you are using all four of the ethernet ports on the Linksys, there is not an option to put the Linksys iinto "bridge" mode. It has to stay a router.
