ronaldvr2132
Apr 08, 2018Apprentice
RBK50: When do we get the product we expected to buy?
I have a RBK50 and like many others I come to the conclusion that this product has nowhere lived up to the promise. I have the following issues: - RBS50 satellite wired connected to the RBK50 router...
Apr 10, 2018Guru - Experienced User
I believe he stated that in his OP. He's using a older version of FW and he should try the v2.1.3.4 version of the FW that available for his model Orbi.
DarrenM wrote:Hello ronaldvr2132
What firmware version are you running?
DarrenM
rdawsoniii
Apr 10, 2018Star
ronald, I wholeheartedly agree!
I've had an Orbi RBK40 for 10 days. Nothing but problems. Disconnects almost every hour. Multiple factory resets, power cycling, turning router/satellite off/on, and syncing....no improvement. Updated firmware...no improvement.
I am still in my Amazon return window. I've got 2 more things I will try tonight. If those don't work, then the Orbi goes back tomorrow. I cannot believe how difficult it is to get this thing working properly. I bought the Orbi because of the dedicated backhaul channel. If I have to send this back, I am going to get my original first choice, the Google.
