Almazar80
May 12, 2020Aspirant
RBK50 will not save second ssid
I bought a refurbished RBK50 kit from Microcenter. It seems to work okay except for one thing. It won't allow me to save the second ssid. I go to the debug page, turn telnet on, telnet to the rout...
May 12, 2020Guru - Experienced User
Almazar80
Thanks for responding. I did all the things that the document you linked to said that I should. And for a few minutes, it does work. Unfortunately, in my case, the router reverts to the single ssid after a short amount of time. I tried this several times. I even check the satellite to make sure that the ssids were propagated after the change and they are. Unfortunately, the system resets after a few minutes and reverts to a single ssid configuration. The other changes I put in place (new router address, DHCP configuration, DMZ setup etc.) are retained. Only the second ssid setup is reverting to the previous configuration.
One thing I haven't tried is to change the ssid after doing a reset. I'll save the configuration, reset the router, and see what happens. It should not make a difference, but perhaps the second ssid can only be set when the router is at the default 192.168.1.1 address.
- CrimpOnMay 12, 2020Guru - Experienced User
If it's not too personal, would you be willing to share the reason for devoting this much effort to creating a second SSID on the Orbi that was clearly designed to host one SSID?
I am 99.9% certain that the IP address of the Orbi router has no bearing on this issue.
- Almazar80May 12, 2020Aspirant
I don't have to have two ssids. I can do with one, and in my use case, it works well enough. Though I always like having finer control of which devices use which band, etc. And since one can supposedly do it, I tried to do it and followed the procedures outlined but found a problem. I guess curiosity why something failed is the paramount reason for this query. I want to try to understand what's happening and why.
I don't think it's the router IP address that's causing the problem either, but I'll reset the router and see what happens. I am using the latest firmware.
