LegendMask
Apr 17, 2019Aspirant
RBK50 with existing router
Hi Im considering getting RBK50 to use it for wifi exclusively, however I have a question setting it up with my isp router/modem. Can it extends my isp modem/router wifi? What I mean by that is,...
LegendMask
Thanks for clarifying that.
Im planning to get the RBK50 as it seems it has the best coverage and speed, but I guess I might need to consider the RBK53 now, since the router RBK will be at the basement. The Bell Home Hub 3000 is really good but unfortunly it doesnt cover my whole home.
The reason I'm getting rid of the Plume mesh pods, is because to be honest they keep dropping connection a lot, and even with 7 pods they still struggle to get even fair signal between each other. (despite even sticking to the recommended range) and I think the main reason behind this issue, is because it doesnt optimize or organize the connections between each pods.
Apr 17, 2019Guru - Experienced User
The RBK is best placed on a main or 1st floor for best single propagation. Basements are not idea and can cause wifi problems.
The system will work wired to your modem. Just besure to set the modem to one of the configurations suggested or try the 3rd option with the Orbi.
Good Luck.
- LegendMaskApr 17, 2019Aspirant
Thank you so much for your replies, and will keep those on my mind when getting either RBK50 or RBK53.
- FURRYe38Apr 17, 2019Guru - Experienced User
:smileywink:
