j1odie
Feb 10, 2023Follower
RBK50 with Verizon FiOS G3100
So I just picked up this mesh system. I left the 3100 as is, connected a included CAT cable from the 3100 LAN to the Orbi WAN. Then I put the Orbi in AP mode, and then disabled all my wifi channels u...
Feb 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
