dondeford
Jul 06, 2020Tutor
RBK50 with Xfinity Modem
I am installing a new Orbi RBK50 with satellite, plus a wall satellite and outdoor satellite from an old system. I have Gig speed internet from Xfinity. I put the Xfinity modem into bridge mode, th...
- Jul 08, 2020
Glad it's working well now.
Please mark your thread as solved so others will know.
Enjoy.
dondeford
Jul 07, 2020Tutor
My Orbi is running version 2.5.1.16.
My Xfinity modem/router is their brand new WiFi6 model, but it doesn't say who manufactures it. When I set it to bridge mode, I also called Comcast and asked them to turn off all router and WiFi functionality on their end, which they said they did, then they rebooted. I could plug a computer directly into the modem and log in and it said that it was in bridge mode. I can't think of anything else to do to get it fully into bridge mode.
I'm ready to reset the modem, turn off bridge mode and put the Orbi into AP mode, but I'm sure the Orbi has a better router than Xfinity does, and I don't want to lose my guest WiFi functionality.
Jul 07, 2020Guru - Experienced User
If you feel the modem is fully bridged. Then keep this configuration.
Try some of the following:
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
