madhur77
Sep 27, 2020Aspirant
RBK50 WLAN link down every 2-3mins
Hi, I have a RBK50 system with a RBR50 router and a RBS50 satellite. Both of them are on firmware version v2.5.2.4. Everything was working fine till recently i started having the Wifi connection ...
CrimpOn
Sep 27, 2020Guru - Experienced User
madhur77 wrote:What i see is that the WLAN (Wireless) link is going down every 2-3mins. I have factory reset the device multiple times, but still have this issue. The wired LAN connections are working fine without issues.
Has anybody come across this issue and are there any solutions for the same. Please help. Thanks.
Yes, WiFi dropping has been posted a number of times. (Perhaps search the forum on "dropping" or something like that.)
When WiFi drops, does it recover by itself?
What sort of reset has been done? (i.e. power off and back on? press the reset button and restart? do a "Factory Reset" and reconfigure the Orbi?
