madhur77
Sep 27, 2020Aspirant
RBK50 WLAN link down every 2-3mins
Hi, I have a RBK50 system with a RBR50 router and a RBS50 satellite. Both of them are on firmware version v2.5.2.4. Everything was working fine till recently i started having the Wifi connection ...
madhur77
Sep 28, 2020Aspirant
Hi,
Thanks for the replies. Yes the wlan link goes down and comes back again in few seconds. Attached a screen grab of the same. This goes on in a loop every few mins.
I tried the following:
1. Factory reset from the admin page.
2. Reset by poking the reset button.
3. Power on and off.
In all the above cases, i reconfigured, but the issue persists and the wlan link is not stable. This is the case only in the router. I have a satellite where everything is working fine. So i had to switch from a wireless backhaul to a wired backhaul, which is working fine. But with everybody online, i need to get the wlan working. Else it is quite difficult. Hence I would still like to understand if my router has gone kaput or is there anything else that can be done to get it back in shape. Let me know if there is anything else i can try. Thanks.
-Maddy
