madhur77
Sep 27, 2020Aspirant
RBK50 WLAN link down every 2-3mins
Hi, I have a RBK50 system with a RBR50 router and a RBS50 satellite. Both of them are on firmware version v2.5.2.4. Everything was working fine till recently i started having the Wifi connection ...
Sep 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Sep 29, 2020Guru - Experienced User
Can you please provide some feedback to these questions.
madhur77What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- madhur77Oct 01, 2020Aspirant
FURRYe38, Here are the details.
Mfr: Huawei
model#: HG630a
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerSize of home: 1500 Sq ft
Distance btw router & satellite: ~20ft
Any Wifi Neighbors near by? If so, how many?2.4Ghz: Tried auto and all the above channels.
5Ghz: Do not have any neighbours on this channel.
Wifi Neighbors: 8-10
Tried all the above options. But no luck.Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Disabled all of the above. But no luck.
As i have shown in my earlier reply with a GIF, there is something that is making the WLAN to restart every few mins.
I am unable to figure out if it is a firmware bug (i.e. some residual left during update) or a hardware failure that is causing this issue.
Is there anything i can check to see if it is truly a hardware failure. Then i can think of ordering a new one as it is of less use without the wifi connection. Thanks.
-Maddy
- FURRYe38Oct 01, 2020Guru - Experienced User
madhur77 wrote:FURRYe38, Here are the details.
Mfr: Huawei
model#: HG630a
This model modem has a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModWhat is the size of your home? Sq Ft?
20 ft is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
