Yong2019's avatar
Yong2019
RBK50 WOL wake on LAN internet
I have a NAS with RBK50. I have sentup DDNS and port forward. I can wake up my NAS in the LAN, but can not wake it up through Internet, when I am outside .
Thanks,
  • CrimpOn's avatar
    CrimpOn
    Could you pleases explain the need to "wake up" a NAS?  (I am so unsophisticated that I have been assuming that a NAS is an appliance that "stays on all the time" waiting to do something.)
    What port did you forward to the NAS?
    DDNS and Port forwarding work when there is not another router in front of the Orbi.  i.e. the Orbi WAN interface has a public IP address.  This is the case with your Orbi, correct?
    Another option is to set up VPN (which also requires DDNS).  I do all sorts of things to devices on my LAN by VPNing (is that a verb?) into the Orbi.
    • FURRYe38's avatar
      Most NAS have power management features which would mostly negate any need of WoL for NAS. Most NAS spin up from there sleep modes if those are enabled upon any network access from a device. I wouldn't see a need for WoL for NAS. Mine certainly don't.
      • michaelkenward's avatar
        michaelkenward
        You can save energy. Every kWh counts when you worry about the climate, not to mention power bills.
        I have NAS boxes for backups that turn off at the end of the day and then WOL when the PCs they are to backup turn themselves on.
        The fact that many NAS devices implement WOL suggests that Yong2019 and I are not the only fruitcakes on the planet.
    • Yong2019's avatar
      Yong2019
      Thank you, CrimpOn
      I tried several ports for WoL, such as 5555,4321,6553. None of them works.
      I do have public IP, since I can access my NAS from the internet.
      I am not sure the port forward for WoL is working.
      Some google said there is something different with netgear routers, maybe need to modify subnet, but I don't know the reason.
      • CrimpOn's avatar
        CrimpOn
        When I Googled for Wake on LAN, the results say that UDP ports 7 and 9 are the most common.
