ddross
Jun 08, 2021Aspirant
RBK50, wont let me reply to emails from my internet provider
I can no longer reply to emails from my internet provided which is Spectrum, they brought their modem out here, and i was able to respond to emails, but I can not with my Orbi System, i just had my c...
CrimpOn
Jun 08, 2021Guru - Experienced User
Is it convenient to attach a screen shot of any error message that pops up when you attempt to send or reply?
(use the "Browse" button at the bottom left of the edit panel. that Photos icon in the menu bar at the top puts images in-line and they have to be approved by a forum moderator before anyone can see them.)
Did you try using a different DNS provider?
- ddrossJun 08, 2021AspirantYes I have and orbi noted my firmware is up to date
- plemansJun 08, 2021Guru - Experienced User
I didn't ever see what you were using for a client.
You're using a web brower but are you logging into spectrum client, are you using outlook, what exactly are you using?
Sorry, I don't have spectrum so can't see exactly what you're doing.
