orbiRBK50
Aug 14, 2019Tutor
RBK50+S. How to allow only n and block a/b/g/ac
Hi, I want to allow only n and disallow all other a/b/g/ac on my orbi router and satellite Thanks in advance
CrimpOn
Aug 14, 2019Guru - Experienced User
It would help to know what issue this is expected to address. 802.11n is a 2.4G standard that is "backward compatible" with earlier standards b and g. 802.11ac is a 5G standard that has nothing to do with 802.11n.
There is not much point in having an Orbi and not allowing 5G. Even if the Orbi was replaced with a 802.11n WiFi, that device would accept b and g connections.
