packsorted
Apr 04, 2020Initiate
RBK50V and Spotify Connect
My Orbi Voice doesn't seem to be working with my Spotify Premium. If I use the Spotify app on either an Android, Iphone or Ipad it can see the Orbi Voice under "Available Devices" but when I select ...
CrimpOn
Apr 10, 2020Guru - Experienced User
From the lack of response so far, my guess is that no one watching this forum has an Orbi Voice unit.
You may be more likely to get a solution by posting in the community forum devoted specifically to the Orbi Voice product:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
Good Luck
- packsortedApr 10, 2020Initiate
Super thanks. Working now anyway, not sure what happened. Have a feeling there is some backend 'sync' between Spotify and Netgear. Just started working on its own the next day
Cheers
CrimpOn wrote:From the lack of response so far, my guess is that no one watching this forum has an Orbi Voice unit.
Good Luck
