clvk07
Jan 17, 2021Tutor
RBK50V Orbi Voice Can not go back to Satellite mode
Hi I put the Orbi voice in extender mode, (had to flash the extender firmware) and now when I try to flash the orbi mode firmware it fails (upgrade failed check the file), any suggestion on how t...
- Jan 18, 2021
Flashing the firmware doesn't switch mode. There's 2 versions of firmware on the RBS40V and the satellite actually stores them both. It switches between them based off switching mode.
https://kb.netgear.com/000061089/How-do-I-set-up-my-Orbi-Voice-in-Orbi-Mode
clvk07
Jan 18, 2021Tutor
CrimpOn wrote:
clvk07 wrote:Hi
I put the Orbi voice in extender mode, (had to flash the extender firmware) and now when I try to flash the orbi mode firmware it fails (upgrade failed check the file), any suggestion on how to revert back to satellite mode?
Did you attempt firmware load through the Orbi router Advanced Tab->Administration->Firmware Update-> Manual Tab, or by connecting directly to the RBS40V web page?
Hi
Yes it is the original RBK40V. I reseated the voice to factory settings, connected to the netgear_ext SSID IP 192.168.1.250 and then went to advanced, firmware manual upload
Jan 18, 2021Guru - Experienced User
- clvk07Jan 18, 2021Tutor
plemans wrote:Flashing the firmware doesn't switch mode. There's 2 versions of firmware on the RBS40V and the satellite actually stores them both. It switches between them based off switching mode.
tried that all good, thanks
- plemansJan 18, 2021Guru - Experienced User
Glad it fixed it for you!
