clvk07
Jan 17, 2021Tutor
RBK50V Orbi Voice Can not go back to Satellite mode
Hi I put the Orbi voice in extender mode, (had to flash the extender firmware) and now when I try to flash the orbi mode firmware it fails (upgrade failed check the file), any suggestion on how t...
- Jan 18, 2021
Flashing the firmware doesn't switch mode. There's 2 versions of firmware on the RBS40V and the satellite actually stores them both. It switches between them based off switching mode.
https://kb.netgear.com/000061089/How-do-I-set-up-my-Orbi-Voice-in-Orbi-Mode
Jan 18, 2021Guru - Experienced User
clvk07
Jan 18, 2021Tutor
plemans wrote:Flashing the firmware doesn't switch mode. There's 2 versions of firmware on the RBS40V and the satellite actually stores them both. It switches between them based off switching mode.
tried that all good, thanks
- plemansJan 18, 2021Guru - Experienced User
Glad it fixed it for you!
