Bradders142
Dec 21, 2020Aspirant
RBK50V satellite power adaptor
Does anyone know where I can get a replacement UK power adaptor for my RBK50V satellite (speaker, not router) please?
michaelkenward
Dec 25, 2020Guru - Experienced User
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
Look at the label on the bottom of your satellite. The try the usual places.
- Bradders142Dec 30, 2020Aspirant
Thank you Michael, I'll do what you suggest 👍🏻
