Carnilo
Oct 15, 2021Aspirant
RBK50V tether issues
Hi Im using RBK50V combo(router + satelite) and I am having issues with the WiFi from the satelite due to having thick concrete walls. So I decided to fix this by tethering the router and the sa...
Carnilo
Oct 23, 2021Aspirant
So tethering the satelite to the router renders the Network map and the Device Manager in the app useless?
Is there anyway I can confirm that the satelite indeed is using the wired connection and not the wireless?
Oct 23, 2021Guru - Experienced User
No.
Check the RBRs web page for status under Conected Devices. IT will show "Wired" and not 5G.
