nil3749's avatar
nil3749
RBK50V vs RBK50
Hi All,    I bought Oribi RBK50V hoping it is comparable to RBK50 with $100 less. It seems satelite in RBK50v has lower backhaul speed, and also wired connection speed limit of 100 MB/sec. I was ho...
  • FURRYe38's avatar
    Yes you can change the preample to long and try.
    How far is the patio form the RBR or the RBS?
    Yes, the RBS40v will have a lower wireless backhaul rate of 866Mpbs. Thought should be good for normal usage and performance.
    WMM should be already enabled...just checking.
