nil3749
Jun 22, 2020Aspirant
RBK50V vs RBK50
Hi All, I bought Oribi RBK50V hoping it is comparable to RBK50 with $100 less. It seems satelite in RBK50v has lower backhaul speed, and also wired connection speed limit of 100 MB/sec. I was ho...
- Jun 29, 2020
Yes you can change the preample to long and try.
How far is the patio form the RBR or the RBS?
Yes, the RBS40v will have a lower wireless backhaul rate of 866Mpbs. Thought should be good for normal usage and performance.WMM should be already enabled...just checking.
nil3749
Jun 29, 2020Aspirant
Hi FURRYe38,
Thanks for your reply. I was waiting for making changes and test before replying. So, there was delay.
Here I have included additional information.
My Internet Service Provider is Xfinity, and modem-router is ARRIS TG1682G.
My connection speed is - Download Speed: 200Mbps, Upload Speed: 5Mbps.
I changed my Xfinity modem/router to following settings and then to Bridge Mode.
2.4 GHz: 802.11 g,n - Channel # 1, 20 MHz
5 GHz: 802.11 a,n,ac - Channel # 36, 40 MHz
My Orbi details are:
Router RBR50 - Firmware version: V2.5.1.16
Satellite RBS40V - Firmware version: V2.5.1.2
My house size is around 2600 sq ft. Wood floor. Both Router and Satellite are on first floor.
Satellite is placed at around 35 ft distance. When I powered on Satelite, it showed Blue light. So, connection is good.
I have around 5-6 wifi in neighborhood.
Based on your suggestion, I changed Orbi setting as follows:
ADVANCED -> Setup -> Wireless Setup
2.4 GHz Channel: 6
5 GHZ Channel: 44
Security Option: WPA2-PSK
2.4 GHz Channel: 6
5 GHZ Channel: 44
ADVANCED -> Advanced Setup -> Wireless Settings
Enable 20/40 MHz Coexistence: Unchecked
Preamble Mode: Short Preamble
Enable Daisy Chain Topology: unchecked
Enable Implicit BEAMFORMING: checked
Enable MU-MIMO: unchecked
Enable Fast Roaming: unchecked
ADVANCED -> Advanced Setup -> IPv6
IPv6: Disabled
IPv6: Disabled
After this, I see difference when conected to Satellite. But there is no difference when connected to Router. I see some drop now when I am outside in patio. Should I change Short Preamble to Long Preamble? Also, I did not see much improvement in basement.
Overall, I see some improvement with Orbi over internet provider supplied modem/router, specifically when I am far.
Any further guidance is appreciated.
Regards.
nil3749
Jun 29, 2020Guru - Experienced User
