Xx-Shadowz-xX
Apr 09, 2022Aspirant
RBK50v2’s RBR50v2 Rebooting or ?
This is my wireless internet setup at home. I have the xfinity internet plan 1Gbps that I get from using the Netgear modem CM1000v2. Now connected to my modem is my RBR50 router only then I have 2 RBS...
Xx-Shadowz-xX
Apr 11, 2022Aspirant
Firmware v2.7.3.22
I also did download the new firmware that just came out and same results we did that also it kept going out less then 5 minutes all day constantly with no stopping I might get lucky once in very good long while of it staying on for about an hour without it rebooting or turning off not sure what happens exactly
Yeah I have done turning on and off modem and router in that order. I done it multiple times and left it off for even more time
CAT# I’m not sure I have to check that but I am using the same Ethernet cable that came with the RBK50v2 kit.
Apr 11, 2022Guru - Experienced User
I would factory reset the RBR and RBS and setup from scratch.
CAT6 is recommended for LAN cabling...
- Xx-Shadowz-xXApr 11, 2022AspirantI have reset already multiple times the RBK50v2 router and both of the RBS50v2 satellites. Still same problem. I bought the RBK50v2 kit barely 3 months ago and it worked perfectly fine no problems at all since then until about the last week or two that it started doing this. I don’t understand how and why this was happening. So then I used another RBR50v2 router that was brand new right out the box went through the setup and everything but still no luck at all with fixing this problem. The same exact thing for the 1st router was happening to the new router also even though it was brand new.
I don’t have anything connected to the RBR50v2 router beside the Ethernet cable from the router to the Netgear CM1000v2 modem from Xfinity with 1Gbps plan- FURRYe38Apr 11, 2022Guru - Experienced User
I would try a different LAN cable between the modem and RBR.
Running out of ideas that two RBR50 v2's are seeing same issue with the CM1000 v2 as the modem.
Something to try. Disconnect the RBR from the modem. Just connect 1 wired PC connected to the RBR. Nothing else. Do you see the RBR continue to reboot? Wondering if the RBR is rebooting while connected to the modem or if this stops with out the RBR being connected to the modem.
- KevinLiTApr 11, 2022NETGEAR Moderator
Hello Xx-Shadowz-xX,
I understand that you are having connectivity issues with your RBR50v2. I have been following the thread and came up with some suggested steps that may help isolate the problem to the network device that is causing compatibility issues.
Please try the following steps:
First, Disconnect the RBR50 from the modem.
Next, Plugin your laptop to verify that you are getting network connectivity.
Then, reset your RBR50.
Next, connect your RBR50 to your modem.
Finally, check to see if RBR50 has a stable internet connection.
If the steps above do not work please let me know as soon as possible!
Best,
Kevin
Community Team
