Xx-Shadowz-xX
Apr 09, 2022Aspirant
RBK50v2’s RBR50v2 Rebooting or ?
This is my wireless internet setup at home. I have the xfinity internet plan 1Gbps that I get from using the Netgear modem CM1000v2. Now connected to my modem is my RBR50 router only then I have 2 RBS...
KevinLiT
Apr 11, 2022NETGEAR Moderator
Hello Xx-Shadowz-xX,
I understand that you are having connectivity issues with your RBR50v2. I have been following the thread and came up with some suggested steps that may help isolate the problem to the network device that is causing compatibility issues.
Please try the following steps:
First, Disconnect the RBR50 from the modem.
Next, Plugin your laptop to verify that you are getting network connectivity.
Then, reset your RBR50.
Next, connect your RBR50 to your modem.
Finally, check to see if RBR50 has a stable internet connection.
If the steps above do not work please let me know as soon as possible!
Best,
Kevin
Community Team
Xx-Shadowz-xX
Apr 12, 2022Aspirant
Never mind about the post I said it was being fine at night I take that back all night today it has been going on and off just like it is during the day. The only reason I can think of why on Sunday night it stayed on was probably due to nobody being home at all and not using the internet since 630pm. Why can this be happening at all it should be on 24/7 with no problems.
It was working perfectly good when I bought it less then 3 months ago and never had a problem. After many days of researching and deciding which mesh system to go with this was the only one that stood out it had the most best reviews with a 4.9/5 stars then any other mesh system. All others were hardly having a rating of 4.0/5.0 stars that I have seen all over. After buying first kit of my first mesh system and setting it up starting from first use I loved the results of it so much that I went about 2 weeks later and bought another RBK50v2 kit to add on another satellite to cover my whole house and keep the other new router as back up just in case. For the first time my house had connection everywhere from top to bottom and even outside my house too with no dead spots and very super fast speed 100x better compare to other routers I have used in the past before this. It was working amazing till about 2 weeks ago this problem had started then not only did the first kit router stopped working as it was before but also the new backup didn’t even work right from the start when I never used it before and completely brand new
