asarkk
Mar 14, 2020Aspirant
RBK50v2 - Reads offline and cannot connect to internet
RBK50v2 router reads offline and no internet connection. Have tried resetting modem and router, no luck. Set up satellite and it reads green but any device connected to the network has no internet ac...
Mar 15, 2020Guru - Experienced User
Power OFF both modem and RBR for 30 seconds, then turn ON the modem and let it sync. Then turn ON the RBR. Check the status.
What the top ring LED indicate?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
You may need to walk thru the setup wizard with a wired PC and web browser...
What FW version is currently loaded on the Orbi?
asarkk wrote:RBK50v2 router reads offline and no internet connection. Have tried resetting modem and router, no luck. Set up satellite and it reads green but any device connected to the network has no internet access. Tried checking for new firmware, but it failes everytime. Any suggestions?
