Mavvie
Mar 03, 2021Follower
RBK50v2 Configuration
Full context...(jump to c. for netgear specific question) Hello all, Trying to maximize the efficiency of a newly-acquired router from ATT (the IFWA40) that we received to replace our outdated Z...
Mar 03, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3 first...
