jhkluger's avatar
jhkluger
RBK50v2 Ethernet Ports Not Working
I have a RBKv2 Orbi, with two RBS satellites, currently running latest firmware 2.7.3.22, as a router off my Xfinity Modem.  It has worked (mostly) fine for the last year, but suddenly the ethernet p...
  • jhkluger's avatar
    jhkluger
    Sep 13, 2021
    Just to close the loop on this, I finally discovered that there was an IP address conflict, caused by one of the devices plugged into a switch I was running off the RBR.  As long as that device is not plugged in, the system appears to be working well via Ethernet and WiFi.
    Thanks for your help (which was more useful than the official Netgear customer service team).
