jhkluger
Sep 09, 2021Aspirant
RBK50v2 Ethernet Ports Not Working
I have a RBKv2 Orbi, with two RBS satellites, currently running latest firmware 2.7.3.22, as a router off my Xfinity Modem. It has worked (mostly) fine for the last year, but suddenly the ethernet p...
- Sep 13, 2021
Just to close the loop on this, I finally discovered that there was an IP address conflict, caused by one of the devices plugged into a switch I was running off the RBR. As long as that device is not plugged in, the system appears to be working well via Ethernet and WiFi.
Thanks for your help (which was more useful than the official Netgear customer service team).
jhkluger
Sep 10, 2021Aspirant
jhkluger wrote:Thanks. I just had a phone call with a Netgear support technician, who also concluded that the RBR LAN ports are bad. But, he was surprised, because he said he has never heard of this happening before, especially when all of the LAN ports on the device are failing.
I will probably get a new unit, although I am not confident this will solve the problem. My instinct is that there is some issue between my Xfinity modem and the Orbi that is causing this, but I don't know how to diagnose that.
FURRYe38 wrote:Do any PC or laptop ethernet connected to the back of the RBR get an IP address of 192.168.1.something or nothing appears?
Thanks. Will look into BYOD option. I also just found this thread on the Xfinity forum and wondering whether there is something in compatible between the Orbi and Xfinity device. https://forums.xfinity.com/conversations/your-home-network/xb7-with-orbi-rbr50-and-rbs50-in-access-point-mode-issue/602db12dc5375f08cd47ce10
jhkluger
Sep 13, 2021Aspirant
- FURRYe38Sep 13, 2021Guru - Experienced User
Glad you found the problem.
Enjoy.
