C_Christian
May 20, 2020Aspirant
RBK53 - en mode Point d'accès - Mu-MIMO plante tout !
Bonsoir, Jusqu'à présent mon routeur Orbi 50 et mes deux satellites Orbi 50 fonctionnaient parfaitement en Daisy Chain et en mode Point d'accès (connecté à ma box Orange). J'avais même le triple-...
- May 20, 2020
You can try a "Factory Reset" and set up the Orbi using the web interface from a wired computer.
As you did before, proceed to the Advanced Tab, Advanced Setup, Router/AP Mode and switch into AP mode.https://www.youtube.com/watch?v=cMw4ePACgc4
I see no reason that Mu-MIMO should have caused the Orbi to fail.
Google Traduction:
Vous pouvez essayer une «réinitialisation d'usine» et configurer l'Orbi à l'aide de l'interface Web à partir d'un ordinateur câblé.
Comme vous l'avez fait auparavant, passez à l'onglet Avancé, Configuration avancée, Mode routeur / AP et passez en mode AP.https://www.youtube.com/watch?v=cMw4ePACgc4
Je ne vois aucune raison pour laquelle Mu-MIMO aurait dû faire échouer l'Orbi.
Bonne chance
CrimpOn
May 20, 2020Guru - Experienced User
Google Traduction:
Bonne chance
C_Christian
May 21, 2020Aspirant
Thanks for your answer and the video !
Effectively, I changed the parameter Mu-MIMO to activated it (I am in "Access Point" mode) and clicked on the "Apply" button... and the router did not reboot properly. So I turned it off with the button but when I turned it on again it did not seem to reboot (I waited 10 minutes) and I obtained the magenta ligth above (perhaps because my Internet Box had also crashed at this time - but I have not seen it).
After that, I realised my Internet box was down (no one at home could access to Internet) and rebooted it. I used a paperclip to reset the router but I did not wait until the led flash amber: I just pushed it one second.
Doing so, the router rebooted and preserved all the configuration I have enter before: the good network name (and password) and the new parameter Mu-MIMO active!
Now it works like that, and I am afraid to change another parameter...
The strange thing is that the router crashed and made the Internet box behind crashed also! My firmware is v2.3.5.30, the last one I presume.
Normally, when changing a parameter, how much time does the router take to reboot? (I have 2 satellites RBS50 with the router RBR50).
And should I be connected with the Ethernet wire to change the parameters of the router?
Best regards,
Christian.
