MartinZo
Nov 06, 2020Tutor
RBK53 - Often Rebooting
Configuration: 1. Vodafone Cable Modem in the basement with 1GBit/s broadband performance from provider. 2. RBR50 Orbi Baseststion in 1st floor but connected to Vodafone cable modem via LAN cable. ...
- Apr 12, 2021
Good to hear. Make sure you do a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark you thread as solved so others will know.
Enjoy. :smileywink:
olympos1625
Feb 09, 2021NETGEAR Employee Retired
Hi MartinZo,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. Are you still experiencing the rebooting? Did update the firmware of the Orbi?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
MartinZo
Feb 10, 2021Tutor
Hi Oliver,
Thank you for your reply.
Yes the issue still occurs 1-2 times day. I have gone through my house and been looking for flaws in the electric system, timer settings, e.g. heating systems impact when started (e.g. power peaks leading to inconsistent power and forcing the wifi system to restart) but couldn’t find any significant signs.I have been in contact with the cable provider vodafone and had them measure the lines and cable router from their side remotely. Everything seems stable there. Nevertheless they‘ve sent me a new coaxial cable and new cable router (shipping currently), I will be watching the situation again then.
The orbi system was updated to the newest firmware last week V2.7.2.104 .
- FURRYe38Feb 11, 2021Guru - Experienced User
The wifi onthe ISP modem should be turned OFF or disabled fully.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849- MartinZoFeb 11, 2021TutorFurry:
for your hints, haven‘t tried them yet. Really, really disappointed, have 4 kids and myself at home for work and homeschooling due to corona, cannot bear an unstable connection anymore...fed up with losing internet in the middle of business calls.
When it works, it works great and is definitely fast as hell, but stability is not as I would expect from a 500€ product...
Cannot get rid of the cable modem from the ISP sonce it delivers wifi for the basement, orbi won‘t reach this area completely.
Uodate: Orbi just rebooted again, strange enough it is always about the same time of the day 21:10-21:15 when it starts rebooting (apart from other rabdom reboots during the day, e.g 12:14 today
also) Have encountered the same evening reboot for weeks..not every evening though but when it happens always around the same time.
Looked around the house for power peaks, timers etc, changed power outlet to outlets more than 50 feet away, still rebooting....so obviously not a ‚radiation‘ or power peak issue.
The next house is more thans 80feet away, thus not any wifi inteference issue...and that would only prevent wifi frombeing performant not cause a total reboot.
Will try your hints but have been there already...weeks ago...so unlikely it will help.
Btw my satellites are about 38 and 50ft away from the AP RBR50
Please help, can I swap my faulty HW RBR50 for a new one or get any clue to make this thing stable!!- CrimpOnFeb 11, 2021Guru - Experienced User
This will sound really "off the wall"........
Can you please open the Orbi web interface, Advanced Tab home page, click on the blue box "Connection Status" and record:
- The least that was obtained, and
- When the lease will expire.
As an example, Spectrum Cable gives my Orbi a one day lease (actually 84,600 seconds) and my Orbi renews the lease when it is half expired (every 12 hours).
Look in the Orbi log and find the bottom entry. (Advanced Tab, Administration, Logs, and scroll down to the bottom.)
Does the bottom line say "[Initialized, firmware version...]"
I am not confident that it is possible to distinguish from the router "Ring Light" between the router rebooting and the router losing and restoring the internet link.
