Kandyman
Apr 17, 2020Aspirant
RBK53 - Okay to use just one satellite?
I purchased an RBK53 a few weeks ago and setup just one satellite (in addition to the router) just because I wanted to test range. The router is setup in AP mode - but that probably doesn't matter f...
Apr 17, 2020Guru - Experienced User
Nice thing is you have the option. If your coverage is great, no you don't need it. but if you find dead spots/weak spots, you can always add it in as needed. and if it causes issues, simply remove it. Fairly easy to do both. Maybe stick it in the garage if you want to play. :)
