Waguih
Apr 19, 2019Aspirant
RBK53 - Router-Satellite Connection
I have an Ethernet cable connecting my Orbi router location and my satellite location. Should I use that cable to connect them or leave them alone to connect via their dedicated link?
Apr 22, 2019Guru - Experienced User
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Yes you can use ethernet to connect the RBR to the RBS satellite:
