MASTERNC
May 19, 2019Initiate
RBK53 - Thermostat will not re-connect to network after power outage
I have a Nexia-enabled thermostat with my American Standard heat pump that connects to wifi for remote control. I bought the Orbi system last weekend and set everything to connect to it, including t...
- May 19, 2019Sorry for the false alarm - got it to work. Was going to toggle wireless off and on but the thermostat would not turn wireless off. I had to find a reboot function in a technician screen. It finally worked after reboot.
MASTERNC
May 20, 2019Guru - Experienced User
Enjoy. :smileywink:
