Mr-Lito
Apr 14, 2019Aspirant
RBK53-100PES WiFi dies
Its been working fine for about 3 months then it just died.
My WiFi dies as soon as it starts up. My mobile/AppleTv/iPads connects to it then it dies and comes back after a few minutes.. Then it di...
Mr-Lito
Apr 21, 2019Aspirant
Hi,
first of all. IM not an IT techguy...
but all of your questions isnt relevent.
I havent changed a thing and it just stops working.
how do i get them replaced?
Apr 22, 2019Guru - Experienced User
Please answer the question so we can better help you. It may not be a faulty Orbi, rather other issues that need to be explored. Questions are VERY relivant.
Mr-Lito wrote:
Hi,
- Mr-LitoApr 22, 2019Aspirant
Fine... im bad at english and cant answer all the questions.
What Firmware is currently loaded? The lateset
What is the Mfr and model# of the ISP modem the NG router is connected too? Irrelevant, not my internet thats not working.
Is the Orbi system operating in Router or AP mode? Router
What is the size of your home? Sq Ft? Irrelevant
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Irrelevant, WiFi dies when im standing next to the routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Dont know, standard? Only one other wifi from my neighbor
What WPA security modes are you using? StandardTry enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Whats that?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Whats that?- FURRYe38Apr 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Irrelevant, not my internet thats not working.Relevant as we are checking to see if there is a router and wifi already built in to the modem or not.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Irrelevant, WiFi dies when im standing next to the routerRelivent as we need to know placement configuration and distance.
Are these enabled?
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Whats that?Are any of these enabled or disabled? Under Advanced Tab/Advanced Settings/Wireless Settings
The more information you can provide, weather relevant or not helps us help you.
Try a factory reset and setup from scratch. If the problem continues, then you'll need to file a support ticket. You have have a faulty unit.- Mr-LitoApr 22, 2019Aspirant
ITS NOT. Only a fibre-splitter or what its called...
Okey, its 2m away from the router, MAX.
Are these enabled?
Still, whats that? im not a techguy. I cant have orbi online at the same time as my backup router, then everything stops working.
Try a factory reset and setup from scratch. If the problem continues, then you'll need to file a support ticket. You have have a faulty unit.Thank you for not reading my problem. Ive allready said ive done it and it still not working. It the WiFi dies as soon as it starts up.
https://www.netgear.com/mynetgear/registration/login.aspx
