Danno1's avatar
Danno1
RBK53-100UKS Orbi AC3000 Tri-Band with Router and 2 Satellites - not working
I have tried and failed to configure my Router and 2 satellites today, and returned, frustratingly, to my old equipment. The two main problems have been: 1 Unable to configure one of the satellites...
  • st_shaw's avatar
    st_shaw
    Oct 16, 2017
    Ethernet connection of satellites is expected in future firmware, but no information on when.
    If you have Ethernet wiring to the office, then a wired access point would be best out there.
    With a distance of 30m, I expect you will have a very difficult time finding a solution that allows you to move from house to office without dropping a call.  Doing this would probably require some sort of outside AP to bridge the gap. Your phone would have to be smart enough to handle the transition gracefully also.
    Good luck.
