brandaopj
Aug 14, 2019Follower
Rbk53 best placement for apartament onde floor
[img]https://i.imgur.com/Dl7ih1e.jpg[/img] Hello, I am about to receive the rbk53 kit and i am thinking the best placement for the router and satelites. I´ve marked with red and orange the 2...
Aug 14, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Any Wifi Neighbors near by? If so, how many? Having many wifi nieghbors near by will be problematic.
Try disabling the following:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
