snoopy77
Aug 12, 2020Aspirant
RBK53 Daisy Chain
I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any...
Mstrbig
Aug 12, 2020Master
snoopy77 wrote:I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any info to say that this is the way it can work. I can see people say you need to ethernet from both satelites to the router.
Yes you can with no issues.
My personal setup is Orbi router connected to ISP modem. switch connected to Orbi router. Sat 1 connected to switch. Sat 2 connected to Sat 1. Switch connected to Sat 2. Various wired devices connected to both switches. Total of 23+ wired and wireless devices, consisting of PCs, tablets, phones, printers, TVs, Android box, Firestick, Receiver, blueray, Alexa and more.
- snoopy77Aug 12, 2020Aspirant
Thanks for the quick response. My setup is similair to yours but I will be using the ISP to the Router with Sat-1 connecting wireless back the Router and then ethernet cable from Sat-2 to Sat-1 and as I say that worked fine.
- FURRYe38Aug 12, 2020Guru - Experienced User
Be sure to check distance between the units. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Enjoy,
- snoopy77Aug 19, 2020AspirantIf I created a star topology wiring each satellite back to the router, do you have to hard wire direct into router or can they go into a switch that's in front of the router?
