snoopy77
Aug 12, 2020Aspirant
RBK53 Daisy Chain
I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any...
snoopy77
Thanks for the quick response. My setup is similair to yours but I will be using the ISP to the Router with Sat-1 connecting wireless back the Router and then ethernet cable from Sat-2 to Sat-1 and as I say that worked fine.
Aug 12, 2020Guru - Experienced User
Be sure to check distance between the units. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Enjoy,
- snoopy77Aug 19, 2020AspirantIf I created a star topology wiring each satellite back to the router, do you have to hard wire direct into router or can they go into a switch that's in front of the router?
- MstrbigAug 19, 2020Master
snoopy77 wrote:
If I created a star topology wiring each satellite back to the router, do you have to hard wire direct into router or can they go into a switch that's in front of the router?You can go to a switch in between the router and satellite. That's how mine is. I have an RBR50 connected to the ISP modem.
- snoopy77Aug 19, 2020AspirantI'll assume you can also plug an ethernet cable from a satellite into an RJ45 socket which can go straight to the Netgear router or switch?
