snoopy77's avatar
snoopy77
RBK53 Daisy Chain
I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any...
  • Mstrbig's avatar
    Mstrbig
    Aug 19, 2020
    snoopy77 wrote:
    I'll assume you can also plug an ethernet cable from a satellite into an RJ45 socket which can go straight to the Netgear router or switch?
    Not a Netgear regular router but yes a Netgear Orbi router. The RBS satellites have to be connected to an Orbi router.
