DLSF
Nov 04, 2019Aspirant
RBK53 Doesn't restart after firmware update
I initiated latest firmware update last night. The router seemed to have difficulty restarting after but eventually did. However, this morning the SSID wasn't broadcasting. Tried power off/on more...
Nov 05, 2019Guru - Experienced User
here's the order I'd try to fix it in.
1. Hard reset. While its powered up, hold the reset button until the lights change. If it doesn't work, go to the next step.
2. Tftp procedure. This allows you to relace the firmware on the router. I'll link to the procedure. Make sure to follow it closely.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
You'll also need to enable tftp from within windows (if you use windows).
https://www.thewindowsclub.com/enable-tftp-windows-10
Tftp has worked well for me to recover from these issues. One thing to make sure you do in the future is to manually do the firmware updates over a hardwired connection. I've had the best results going this route.
DLSF
Nov 06, 2019Aspirant
Thanks for the information. I didn't get very far as I don't have adminstrator control over the computer I tried to use so I couldn't make configuration changes required for the transfer. I've only had the system 3 months and decided I shouldn't be going through the hassle anyway. After 3 calls to their support team Netgear agreed that the system is defective and is providing a replacement. My concern is that it'll happen again since this is the second unit that failed. thanks again
- Retired_MemberNov 06, 2019
From OP:
That's too bad....It's hard to believe how a firmware update broke your Orbi. Was it working before?
- DLSFNov 06, 2019Aspirant
Yes, it was working fine for 3 months.
Just a couple of closing comments....the lack of admin control on the PC...?? Not sure what that means. Sounds like a separate issue.
If NG has agreed to send replacement(s), that a good thing. My advice is once your new system is up and running, leave it alone. DO NOT execute manual firmware updates. NG will push them to you when you need them.
