xavierhazzard
Jul 11, 2020Follower
RBK53 ethernet speed slow
I have just setup my RBK53 and the WiFi speed is great. I get 380 in all the rooms the satellites are in. However when it comes to my ethernet, the speeds aren't so great. I pay for 350mbps and I was ...
Jul 13, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mstrbig
Jul 31, 2020Master
If I'm reading your post correctly, it doesn't make sense that you get 380Mbps WIFI in all the rooms the satellites are in. But your ethernet speeds aren't so great, as you are getting 130 max.
You've already ruled out the cable. Have you rebooted the ISP modem and/or re-configured the Orbi?
