aliakaraz
Aug 28, 2020Aspirant
RBK53 Firmware V2.7.0.70 - Missing Devices
I've just updated to firmware v2.7.0.70 and everything seemed ok. I've now noticed both the orbi app and the website portal are not showing all my connected devices. Example in point my switch, echo ...
aliakaraz
I didn't know there were different versions...do you know how I can check this?
I only bought it in January 2020 so I'd assume it's the latest version.
CrimpOn
Aug 28, 2020Guru - Experienced User
V1 has a USB port on the back. V2 does not have a USB port.
- aliakarazAug 28, 2020Aspirant
Ok, so it's v1 as it does have USB on the back.
- MstrbigAug 28, 2020Master
aliakaraz wrote:Ok, so it's v1 as it does have USB on the back.
Firmware V2.7.0.70 is for the V2 system.
Current firmware, even though others have reported newer pushed or loaded versions, is 2.5.1.16
Thanks for that. I suppose I'll have to manually downgrade the firmware back to 2.5.1.16.
