aliakaraz
Aug 28, 2020Aspirant
RBK53 Firmware V2.7.0.70 - Missing Devices
I've just updated to firmware v2.7.0.70 and everything seemed ok. I've now noticed both the orbi app and the website portal are not showing all my connected devices. Example in point my switch, echo ...
aliakaraz
Ok, so it's v1 as it does have USB on the back.
Mstrbig
Aug 28, 2020Master
aliakaraz wrote:Ok, so it's v1 as it does have USB on the back.
Firmware V2.7.0.70 is for the V2 system.
Current firmware, even though others have reported newer pushed or loaded versions, is 2.5.1.16
- aliakarazAug 28, 2020Aspirant
Thanks for that. I suppose I'll have to manually downgrade the firmware back to 2.5.1.16.
