Hinkvdp
Aug 01, 2021Tutor
RBK53 flashing white light
Dear, i've a orbi RBK53 and since a last reboot, the router is continously flashing white with no internet as a result. I can't connect anymore via ip-address or via website to the router. It a...
- Aug 06, 2021
Hi,
the problem is solved..
It was a corrupted installation of the new firmware which messed up the whole system.
After a new download (from the netgear-website) and a reinstallation on both Router and the 2 satelittes, the issue was solved.
Thanks for the support,
Kind regards,
Hink
Aug 05, 2021Guru - Experienced User
Any updates on this?
Hinkvdp wrote:
Dear,
i've a orbi RBK53 and since a last reboot, the router is continously flashing white with no internet as a result. I can't connect anymore via ip-address or via website to the router. It appears that the system is death.
I've read how to install manually the firmware update via eternet cable but that didn't help neither.
We've both the orbi in May 2019, so pretty young to have a faitall system error.
Any suggestions ?
Thanks,
Hink
- HinkvdpAug 06, 2021Tutor
Hi,
Kind regards,
Hink
- FURRYe38Aug 06, 2021Guru - Experienced User
Glad you got it working.
Enjoy.
