Hinkvdp
Aug 01, 2021Tutor
RBK53 flashing white light
Dear, i've a orbi RBK53 and since a last reboot, the router is continously flashing white with no internet as a result. I can't connect anymore via ip-address or via website to the router. It a...
- Aug 06, 2021
Hi,
the problem is solved..
It was a corrupted installation of the new firmware which messed up the whole system.
After a new download (from the netgear-website) and a reinstallation on both Router and the 2 satelittes, the issue was solved.
Thanks for the support,
Kind regards,
Hink
Hinkvdp
Aug 06, 2021Tutor
Hi,
Kind regards,
Hink
Aug 06, 2021Guru - Experienced User
Glad you got it working.
Enjoy.
