mikeamor
Nov 21, 2018Follower
RBK53 Intereferes with ioGearHDMI Transmitter
We recently replaced our home network that was using a Nighthawk router with the Orbi rbk53.
The 5G radio on the Orbi intereferes with our HDMI transmitter, an IOGEAR GW3DHDKIT, to the point is can...
Nov 21, 2018Guru - Experienced User
How close is the Orbi system to this device? It should be as far apart as possible.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Can you change channels on this device to something else? You can change channels on the Orbi however there are only 4 channels you can change.
You can not disable any radios on the Orbi system.
You can turn down the 5Ghz radio power out put and test. Try setting from 100% to 75 or 50%.
