mikeamor
Nov 21, 2018Follower
RBK53 Intereferes with ioGearHDMI Transmitter
We recently replaced our home network that was using a Nighthawk router with the Orbi rbk53.
The 5G radio on the Orbi intereferes with our HDMI transmitter, an IOGEAR GW3DHDKIT, to the point is can...
st_shaw
Nov 21, 2018Master
You cannot turn off the 5 GHz on Orbi. WiFi needs 5 GHZ for proper operation with modern devices The best solution would be to buy an HDMI transmitter that uses a frequency that does not overlap with WiFi. There are several that operate at 60 GHz. See the thread linked above for some options.
