GadgetVirtuoso2
Apr 05, 2020Apprentice
RBK53 issues with 2.5.1.8
Add me to the list of everyone having issues with 2.5.1.8. Yesterday I completely reset the unit and it worked for about a day. Now a day later I'm having issues with WiFi all over again. Anything pl...
PCSP
Apr 05, 2020Guide
Should I update firmware 2.5.1.8? Now I stay at 2.3.5.30 for a few months
Apr 06, 2020Guru - Experienced User
If your system is working, keep it on whats working. If you choose to update, manually download the FW files from NGs download support site first, then install the RBS first then RBR lastly. I recommend a factory reset and setup from scratch after updating.
PCSP wrote:Should I update firmware 2.5.1.8? Now I stay at 2.3.5.30 for a few months
