GadgetVirtuoso2
Apr 05, 2020Apprentice
RBK53 issues with 2.5.1.8
Add me to the list of everyone having issues with 2.5.1.8. Yesterday I completely reset the unit and it worked for about a day. Now a day later I'm having issues with WiFi all over again. Anything pl...
GadgetVirtuoso2
Apr 08, 2020Apprentice
I loaded the Voxel FW and everything was good for about 36 hours, then everything went to hell.
Today is turned off both satellites and tried running on just the router. Connection constantly drops. 5Ghz devices can't connect to 5Ghz. Devices can't get IPs and are disconnected. I've turned off nearly every feature possible. This hardware is complete crap. There's no reason that the hardware should perform so poorly after 18 months give or take.
Retired_Member
Apr 09, 2020
GadgetVirtuoso2 wrote:I loaded the Voxel FW and everything was good for about 36 hours, then everything went to hell.
Sounds like you need to dump 2.5.1.8
amd stop performing manual firmware updates
