ElCapo
Sep 08, 2021Luminary
RBK53 Network Dropping
Hello All I have a RBK53 set up in my house running V2.7.3.22. I have Ethernet Backhaul connecting my Satelites to my main router. I have Virgin Cable with the internet connecting in pass...
Sep 08, 2021Guru - Experienced User
Does the top ring LED turn ON when this happens on the RBR or RBS?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
ElCapo
Thanks for the response. Some answers below:
Virgin HUB4 TG3492LG-VMB
This DOES NOT happen when the network goes down. There is no external indicator on the ORBI to show a problem is occuring
My ORBIs are wired backhaul so not relevant here.
Only one other wifi network is visible to my house
Possibly not no for a whole minute. Although a few reboots have happened
- FURRYe38Sep 08, 2021Guru - Experienced User
What mode is thes modem working in? Router or Bridge?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopDoes the top ring LED turn ON when this happens on the RBR or RBS?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡My ORBIs are wired backhaul so not relevant here.
Regardless of backhaul, distance IS relevant and can impact good operation and cause problems.
Are the RBS directly connected to the RBR or is ther a LAN switch in the middle? If there is a switch, brand and model# please.
A full power OFF by pulling the power adapter should be performed for 1 minute or more.
- ElCapoSep 08, 2021Luminary
Hi Flurry, answers below:
The modem is in bridge mode, so my local network is being managed by the Orbi router only.
I do have a number of netgear unmanaged switches in my home network, models such GS608v3, plus newer versions of the same. However, I have intentionally ensured that my satelites are directly cabled to back to the Router and do not go via switches.
I will try this and report back.
Ok. I would also turn OFF the RBS and switches and just run the RBR to see if the problem continues. Keep an eye on the top ring LED for any appearance here as well.
Another suggestion would be to put the modem back to router mode then configure AP mode on the RBR to see if the problem continues or not...if it does, a full on factory reset maybe needed.
